[fdo-internals] FDO OGR Provider: NULL values in integer Field
Traian Stanev
traian.stanev at autodesk.com
Thu Feb 25 11:03:16 EST 2010
Hi again,
I have compiled two versions of the OGR provider with FDO 3.4/MG2.1. One does a static link to GDAL 1.7, with PostGIS support -- it requires you to provide libpq.dll. The other does dynamic link to GDAL 1.7, so you can plug in your own GDAL dll. This can coexist with the one used by FDO, since FDO 3.4 is using GDAL 1.6 (which uses a different filename).
Greg has posted the files at:
http://download.osgeo.org/fdo/3.4.1/patches/
I gave some quick testing to the static-link dll. I have not yet had time to test the other one.
Traian
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: Tuesday, February 23, 2010 6:22 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] FDO OGR Provider: NULL values in integer Field
@Traian
> If I get a chance in the next week, I might port the fix to 3.4 and post a new build of the provider.
Perfect, thank you. Please notify to the list when a new build is available.
@Greg
> If you need any assistance, I would be happy to help with any build/post tasks.
Thank you for you offer.
Regards,
Gabriele
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
