[fdo-internals] Common Xerces for MapGuide and Fdo
Zac Spitzer
zac.spitzer at gmail.com
Thu Jul 1 20:00:52 EDT 2010
How about an embeded version check? It's painful enough
with people always trying to build mapguide with the wrong FDO
version
On 2 July 2010 06:42, Jason Birch <jason at jasonbirch.com> wrote:
> I'm personally in favour of this. We can state supported/minimum
> versions somewhere on the wiki (in release notes?) but using system
> libraries is better for our users and for the project. It ensures that
> we work to become part of the open source community, coexisting with
> other library installations, contributing patches upstream, etc.
> On 2010-07-01, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
>> Hi list,
>> As part of the MapGuide Oem library upgrades for the next release, we will
>> be moving to Xerces 3.1.0 (or maybe 3.1.1) to match Fdo. The work is being
>> done by Rohit, our Google Summer of Code Student. For MapGuide, we are
>> intending to remove Xerces from our source tree and use previously installed
>> "-dev" packages on Linux and official Xerces "SDKs" on Windows. Since
>> Xerces 3.1.0 is not available on CentOS 5, we will be building and
>> distributing the RPMs ourselves.
>> In an effort to share the same physical library on both Linux and Windows,
>> we were wondering if it would make sense to follow the same process for Fdo,
>> ie. pull Xerces out of the tree and build against an "installed" version of
>> Xerces for both Linux and Windows? As a side note, building against
>> installed "/usr" libs on Linux would bring us one step closer to Debian /
>> Ubuntu packaging compliance.
>> Is this approach reasonable?
>> Regards,
>> Trevor
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fdo-internals
