[fdo-internals] RE: FDO RFC 48 - Polygon Vertex Order is ready
for review.
Orest Halustchak
orest.halustchak at autodesk.com
Tue Jul 13 11:51:15 EDT 2010
The capability function is useful for the cases where the vertex order does matter so that clients can find that out from the provider rather than doing hard coded checks. E.g. for SQL Server, if you insert a polygon with the wrong vertex order, you'll get an error.
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Tuesday, July 13, 2010 11:29 AM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: FDO RFC 48 - Polygon Vertex Order is ready for review.
I guess it depends on your definition of "needs fixed". For most uses, like rendering and editing, the vertex order doesn't matter. For uses where it matters, the code already has to deal with both kinds of winding, so such report will be unnecessary. That's why I keep questioning the addition of this new capability -- it doesn't add useful information for FDO clients, due to already existing incorrect data which cannot be ignored.
Traian
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Tuesday, July 13, 2010 11:22 AM
Silly question if the existing data is bad don't we need some kind of report to identify what needs fixed or do we have a tool that lets the customer fix the problem polygons?
Dave
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Leaf Li
Sent: Monday, July 12, 2010 7:06 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] RE: FDO RFC 48 - Polygon Vertex Order is ready for review.
Thanks for your clarification. Yes. I think Oracle should be enforced too.
Thanks,
Leaf Li
>Date: Mon, 12 Jul 2010 06:00:07 -0700 (PDT)
>From: Crispin_at_1Spatial <crispin.hoult at 1spatial.com>
> ready for review.
>Message-ID: <1278939607633-5282779.post at n2.nabble.com>
>Content-Type: text/plain; charset=us-ascii
>I think (clarification) that Oracle will indeed store SDO geometry with all
>sorts of geometric and validation errors (and FDO will retreive it).
>However, for spatial analysis to be carried out on the data the data must
>pass validation. This means that the Oracle provider(s) sit somewhere
>between needing enforcement and not.
>I would like to think that FDO had the capability to ensure that geometry
>was valid for Oracle as other processes (apart from visualisation or
>bounding box filter) may be required to operate between individual
>geometries.
>View this message in
>context: >http://osgeo-org.1803224.n2.nabble.com/RE-FDO-RFC-48-Polygon-Vertex-Order-is-ready-for-review-tp5281359p5282779.html
>Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
