[fdo-internals] RE: New RFC 49 Posted
Dan Stoica
dan.stoica at autodesk.com
Sun Jun 6 15:09:29 EDT 2010
The proposal is to pass programmatically the tolerance to FdoSpatialUtility::Evaluate().
I wonder how is it going to be used by an application since usually Evaluate() is called indirectly by Select:
FdoPtr<FdoSpatialCondition> filter = FdoSpatialCondition::Create(<geometryPropertyName>, <spatialOperator>, <geometry>);
select->SetFilter(filter);
Hence the tolerance should be passed as well to FdoSpatialCondition::Create() like:
FdoSpatialCondition::Create(<geometryProperty>, <spatialOperator>, <geometry>, toleranceXY, toleranceZ);
On the other hand, managed C++ does not accept default parameters as suggested.
This said, it seems to me that the way to go is to add setters/getters to FdoSpatialCondition and Evaluate() needs a new override rather than a signature extension.
Thanks,
Dan.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Romica Dascalescu
Sent: Wednesday, June 02, 2010 9:14 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] New RFC 49 Posted
RFC 49 (http://trac.osgeo.org/fdo/wiki/FDORfc49) is now ready for review. The main purpose is to change FDO API spatial functions to be able to provide tolerances (XY & Z) used for spatial evaluation.
Please review and provide additional feedback.
Thanks,
Romy.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
