[fdo-internals] Re: FDO 3.5.0 RC1
Traian Stanev traian.stanev at autodesk.com
Tue Mar 2 10:35:01 EST 2010
I think it's worth having a more general conversation about which of the version strings of a provider is the one that matters:
1. The one returned by FdoIConnectionInfo::GetProviderVersion
2. The stamped into the DLL by stampver
3. The one given by providers.xml <Version> tag
4. The one given by the name of the provider in providers.xml
There are also:
1. the FDO version returned by the provider
2. the FDO version given in the providers.xml entry for the provider
3. the version encoded in the name of the provider in providers.xml
The last three are always kept the same as the first four (apart from the stamp having build number in it perhaps), so one can argue that providers themselves don't have a version -- their version is given by the version of FDO in use.
Also, as far as I know none of those version strings are used in a meaningful way by FDO client applications. Even the version part of the provider name gets slashed off the name of the provider a lot of the time (see for example MapGuide's serverconfig.ini).
Do we need seven places encoding the same version string?
Traian
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, March 02, 2010 10:13 AM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Re: FDO 3.5.0 RC1
Also, I see the provider name in the providers.xml file is 3.5.
Someone should make naming and versioning in this provider consistent and publish the public information applications should expect to this mail list.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: Tuesday, March 02, 2010 3:27 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Re: FDO 3.5.0 RC1
Minor thing -- the Win32 "File Version" for the KingOra files is "0.8.10" for
two and "0.8.13" for the other which is a bit odd
View this message in context: http://n2.nabble.com/FDO-3-5-0-RC1-tp4655350p4659666.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
