[fdo-internals] RE: Oracle 10.2.0.3 Linux instant client
Trevor Wekel
trevor_wekel at otxsystems.com
Tue Mar 9 13:42:39 EST 2010
Ok. I will submit the changes to the Makefile.am's for 3.5.0 and trunk.
Thanks,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: March 9, 2010 11:30 AM
To: FDO Internals Mail List
Subject: [fdo-internals] RE: Oracle 10.2.0.3 Linux instant client
I say we move the KingOracle provider to use the Oracle 11 client on Linux. I know it is not optimal, but I think the risks are fairly minimal. We may wish to do the same for Windows, but I think that is less of an issue.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Tuesday, March 09, 2010 11:54 AM
Hi Greg,
-lnnz10 is also a problem. Oracle renamed this library to libnnz11.so for Oracle 11. The additional -L and -I directives can coexist but we can only pick one version of libnnz.
On the plus side, compilation against the Oracle 11 instant client worked without a hitch and the c++ libraries are consistent. I have not tested the provider yet since I do not have an Oracle database set up.
Upgrading the Oracle client library after RC1 is probably a bit naughty from a "release" standpoint. However, mixing c++ libraries seems like an accident waiting to happen.
Please note: This dual c++ library problem should also manifest itself with other shared libraries build against the 10.2 client on CentOS/RedHat 5.
What should we do?
Regards,
Trevor
Sent: March 9, 2010 9:34 AM
Yes... The Makefile changes are all I anticipate.
Sent: Tuesday, March 09, 2010 11:21 AM
Ok. No problem. I assume we only need to make two small changes to -L and -I directives in KingOracle/src/Makefile.am and KingOracle/src/Provider/Makefile.am?
I will try it out.
Thanks Greg,
Trevor
Sent: March 9, 2010 9:08 AM
We can change the compiler settings to first look for oracle 11 and then oracle 10. It is not a big change.
Sent: Tuesday, March 09, 2010 9:48 AM
Subject: [fdo-internals] Oracle 10.2.0.3 Linux instant client
Hi everyone,
I have been doing some .so dependency checking on Linux and have noticed that the Oracle 10.2.0.3 instant client used to compile the King.Oracle Provider contains shared lib references to libstdc++.so.5. This is the c++ library for GCC 3.4. However, we compile Fdo under GCC 4.1 so we end up referencing both libstdc++.so.5 and libstdc++.so.6.
From a previous discussion, mixing headers from different C++ libs is problematic. Will this mix of c++ libraries cause problematic behaviour (memory leaks, etc) with the King.Oracle Provider? If so, do we need to upgrade the Oracle instant client? I downloaded the 11.2 instant client and it correctly links to libstdc++.so.6. I do not know if King.Oracle will compile against it though.
Please note, this would not a problem when compiling under CentOS/Redhat 4 since the default compiler was gcc/g++ 3.4.
Regards,
Trevor
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20100309/03419e5b/attachment-0001.html
More information about the fdo-internals
