[fdo-internals] Dropping off PSC
Daniel Morissette dmorissette at mapgears.com
Mon Nov 8 09:03:58 EST 2010
Hi Leaf,
I am sorry, I gave you the wrong user name for anonymous access... I
checked again and it is "cvsanon at cvs.maptools.org"
Can you please try again with
CVSROOT=:pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot
Daniel
Leaf Li wrote:
> Hi Daniel,
> I turn off firewall in my computer and get the following error message.
> In C:\DOCUME~1\asus\LOCALS~1\Temp\: "C:\Program Files\CVSNT\cvs.exe" -q -Q co -c
> CVSROOT=:pserver:cvs.maptools.org:/cvs/maptools/cvsroot:
> Empty password used - try 'cvs login' with a real password
> cvs [checkout aborted]: unrecognized auth response from cvs.maptools.org: cvs [pserver aborted]: /cvs/maptools/cvsroot:: no such repository
> Error, CVS operation failed
> Actually I can use my TortoiseCVS to check out other depot. Can you double check whether MITAB depot really supports anonymous login.
> Thanks,
> Leaf Li
> ________________________________________
> From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] on behalf of Daniel Morissette [dmorissette at mapgears.com]
> Sent: Thursday, November 04, 2010 10:50 PM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] Dropping off PSC
> Daniel Morissette wrote:
>> Leaf Li wrote:
>>> By the way, do you know the address of MITAB SVN depot. I just know GDAL/OGR SVN depot contains it.
>> It's a CVS repository on the maptools.org server, the CVSROOT is:
>>   :pserver:dmorissette at cvs.maptools.org:/cvs/maptools/cvsroot
>> and you should be able to checkout the latest source using user
>> "anonymous" and an empty password.
> Um... I've been too quick on the copy/paste. The CVSROOT for anonymous
> access would be:
>   :pserver:anonymous at cvs.maptools.org:/cvs/maptools/cvsroot
> ... and then "cvs login" with an empty password...
> ... and then "cvs checkout mitab" to get the source...
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals_______________________________________________
Daniel Morissette
More information about the fdo-internals mailing list
