[fdo-internals] Self Build Thirdparty (curllib) on Windows
Greg Boone greg.boone at autodesk.com
Tue Nov 16 09:37:17 EST 2010
"build_thirdparty -a=wms"
That call is not needed nor is it valid. It should actually complain.
Typically, to build WMS Thirdparty, I call "build_thirdparty -w=fdo -w=wms"
I don't remember seeing the error you identify below.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: Tuesday, November 16, 2010 6:23 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Self Build Thirdparty (curllib) on Windows
I am quite happy building FDO third-party, and FDO from 3.4, 3.5 etc for
most of the providers but when I do a...
 to enable
build -w=wms
... to then I always get the same dependency type messages.
Is this the correct way to do the WMS build?
 Crispin
Time Elapsed 00:00:00.42
Build started 16/11/2010 11:02:14.
Project "E:\Projects\FDO\trunk\Thirdparty\libcurl\lib\curllib.sln" on node 0
(Build target(s)).
  Building solution configuration "release|Win32".
e:\projects\fdo\trunk\thirdparty\libcurl\lib\urldata.h(71): fatal error
C1083:
Cannot open include file: 'openssl/rsa.h': No such file or directory
C1083:
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Self-Build-Thirdparty-curllib-on-Windows-tp5743435p5743435.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
