[fdo-internals] FDO 3.5 final release?
Haris Kurtagic haris at sl-king.com
Sat Sep 4 13:25:38 EDT 2010
I build boost win32 and win64 few times and didn't had any issues.
Haris
On Sat, Sep 4, 2010 at 4:43 PM, Trevor Wekel
<trevor_wekel at otxsystems.com> wrote:
> Hi Greg,
> Ok.  I will try the 32 bit build.  I am still getting can't open file .obj.rsp from boost when running the 64 bit build.  Here are the commands I am running on branches/3.5.
> svn export svn://localsvnrepo/fdo/branches/3.5 c:\builds\fdo35x64\fdo
> cd c:\builds\fdo35x64\fdo
> setenvironment.bat x64
> build_thirdparty.bat -p=x64 -a=buildinstall -o=c:\builds\fdo35x64\install
> One modification I did make to setenvironment.bat was to update the Visual Studio path
> SET ACTIVEPATHCHECK="C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC"
> Regards,
> Trevor
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
> Sent: September 3, 2010 3:52 PM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] FDO 3.5 final release?
> Hi Trevor,
> I tried building boost Win32 on a Win64 OS using the Visual Studio x86 compiler tools and I didn't encounter any issues.
> Greg
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
> Sent: Tuesday, August 31, 2010 12:55 AM
> Hi Greg,
> I am able to build the following:
> Windows: MySQL, ODBC, PostgreSQL, GDAL, KingOracle, OGR, PostGIS, SDF, SHP, SQLite, WFS, WMS
> Linux: MySQL, ODBC, PostgreSQL*, GDAL, KingOracle, OGR, PostGIS*, SDF, SHP, SQLite, WFS, WMS
> *For Linux, I may have build issues with PostgreSQL and PostGIS related to the Thirdparty pgsql libs.  I get a number of unresolved externals for both providers and need to investigate further.
> Regards,
> Trevor
> Sent: August 30, 2010 10:07 PM
> Trevor,
> What builds (minus ArcSDE) are you capable of posting? Why don't we focus on posting what you can build right now.
> I can work on posting the ArcSDE libraries once you have posted the main build. I can also look to see if I can reproduce the boost x86 issue so you can perform the win32 build on your win64 machine.
> As for testing, I propose we post and have the community validate.
> Greg
> Sent: Monday, August 30, 2010 11:34 PM
> So a number of submissions have been made lately. Are there any objections to having these included in a new candidate build?
> Sent: Saturday, August 28, 2010 12:35 PM
> Hi Jackie,
> Your question is timely.  I have been discussing the FDO builds offline with Greg and others over the past few months.  Since MapGuide needs FDO for Windows and Linux, I thought it was reasonable for me to do the FDO builds as well.  I believe there are a few things we need to address:
> 1.  Build OS for Windows
> Currently, the FDO 3.5 builds are cleaner on a 32 bit OS.  From what I recall, one of the third party dependencies (boost?) is a bit out of date and gets a little cranky with the (x86) in the path name.  I believe this has been resolved in FDO trunk.  The 32/64  bit OS wouldn't normally matter but I was foolish enough to install a 64 bit OS on the MapGuide build machine.
> We have a couple of options available to resolve this:
> a.  Set up a separate build VM for FDO with a 32 bit OS.
> b.  Update the third party libs and compile using the existing MapGuide 64 bit build VM.
> Option a. is cleaner and I think it would be better if FDO had its own build machine.  I suppose I can eat the licensing cost (bummer).
> 2. ArcSDE Providers
> I do not have access to ESRI SDKs so I cannot build the ESRI FDO Providers.  If someone else in the community would be willing to build the ESRI Providers, that would be great.
> 3. Resourcing
> To be honest, I am very busy right now and would welcome a collaborator on the FDO builds.  The build infrastructure is web accessible and I would be more than willing to give access to anyone able to help out with the FDO builds.
> 4. Build Validation
> I am competent in FDO but not an FDO expert.  And with 10(+?) providers to test, build validation is a major undertaking.  We should open up a discussion on appropriate build validation steps.  Builds are fine.  Builds that work are better.
> Regards,
> Trevor
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: August 28, 2010 2:45 AM
> To: fdo-internals at lists.osgeo.org
> Subject: [fdo-internals] FDO 3.5 final release?
> Hi All,
> Is there any word/plans on a final FDO 3.5 release? The download site only has the RC1 release and that itself is several months old now.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-3-5-final-release-tp5472205p5472205.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
