[fdo-internals] Re: insert error control properties with KingOracle
mdelsinne mdelsinne at gmail.com
Thu Dec 1 10:10:40 EST 2011
Mon code:
// Connexion
IConnectionManager connManager =
FeatureAccessManager.GetConnectionManager();
IConnection conn = connManager.CreateConnection("OSGeo.KingOracle.3.6");
IConnectionPropertyDictionary connProperties =
conn.ConnectionInfo.ConnectionProperties;
OSGeo.FDO.Connections.ConnectionState connState = conn.ConnectionState;
connProperties.SetProperty("Username", "FDO");
connProperties.SetProperty("Password", "FDO");
connProperties.SetProperty("Service", "BASETEST");
connProperties.SetProperty("OracleSchema", "FDO");
connProperties.SetProperty("KingFdoClass", "MYFDOCLASS");
connState = conn.Open();
// Schema & Class
FeatureSchema aFeatureSchema = new FeatureSchema("KingOra", "");
FeatureClass aFeatureClass = new FeatureClass("CLASSTEST", "");
string proj = "";
// Add a key property
DataPropertyDefinition keyProp = new DataPropertyDefinition("KEY", "");
keyProp.DataType = DataType.DataType_String;
keyProp.Length = 255;
aFeatureClass.Properties.Add(keyProp);
// Add a name property
DataPropertyDefinition nameProp = new DataPropertyDefinition("NAME", "");
nameProp.DataType = DataType.DataType_String;
nameProp.Length = 255;
aFeatureClass.Properties.Add(nameProp);
// Add a url property
DataPropertyDefinition urlProp = new DataPropertyDefinition("URL", "");
urlProp.DataType = DataType.DataType_String;
urlProp.Length = 255;
aFeatureClass.Properties.Add(urlProp);
// Add a geometry property
GeometricPropertyDefinition geomProp = new
GeometricPropertyDefinition("GEOM", "");
geomProp.GeometryTypes = (int)GeometryType.GeometryType_MultiGeometry;
aFeatureClass.Properties.Add(geomProp);
aFeatureClass.GeometryProperty = geomProp;
// implement the changes
aFeatureSchema.Classes.Add(aFeatureClass);
IApplySchema applySchema =
(IApplySchema)conn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_ApplySchema);
applySchema.FeatureSchema = aFeatureSchema;
applySchema.Execute();
applySchema.Dispose();
// Preparer insertion des données
IInsert cmdInsert =
(IInsert)conn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Insert);
cmdInsert.SetFeatureClassName("FDO~CLASSTEST~GEOM");
FgfGeometryFactory factory = new FgfGeometryFactory();
IDirectPosition position = factory.CreatePositionXYZ(2, 2, 0);
IPoint point = factory.CreatePoint(position);
cmdInsert.PropertyValues.Add(new PropertyValue("KEY", new
StringValue("strKey")));
cmdInsert.PropertyValues.Add(new PropertyValue("NAME", new
StringValue("strName")));
cmdInsert.PropertyValues.Add(new PropertyValue("URL", new
StringValue("strUrl)));
cmdInsert.PropertyValues.Add(new PropertyValue("GEOM", new
GeometryValue(factory.GetFgf(point))));
// Insert
IReader reader = cmdInsert.Execute();
if (reader.ReadNext())
reader.Close();
Result in Oracle:
http://osgeo-org.1803224.n2.nabble.com/file/n7050862/ora1.jpg
http://osgeo-org.1803224.n2.nabble.com/file/n7050862/ora2.jpg
Thank's
View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7050862.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
