[fdo-internals] Re: SQL2008 Views for displaying map
Jackie Ng jumpinjackie at gmail.com
Wed Jun 1 04:48:32 EDT 2011
This is not the right mailing list to discuss such problems.
To answer you particular question, use the schema override functionality to
declare an identity property for your feature class that is the logical
representation of your SQL Server view, save the resulting override as a
configuration document and use upload that into your MapGuide Feature Source
Example with FDO Toolbox and Maestro:
http://themapguyde.blogspot.com/2010/09/using-fdo-schema-overrides-redux.html
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQL2008-Views-for-displaying-map-tp6425767p6426096.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
