[fdo-internals] RE: FDO RFC 61 ready for review
Haris Kurtagic haris at sl-king.com
Thu May 26 03:23:58 EDT 2011
For function 'GetAvailableSavePoints' I am not aware there is
something on DB side that supports it ?
SavePoints are part of application logic, when to add them and rollback ...
I don't think provider should be bothering with keeping updated on
savepoint list.
Haris
On Thu, May 26, 2011 at 8:46 AM, Sam Wang <Sam.Wang at autodesk.com> wrote:
> Hi Dan,
> Thanks for  your comments.  I have updated the RFC accordingly.
> In order to use FdoNamedCollection which requires that the template argument "OBJ" class must provide method GetName() and CanSetName(). So a new class named FdoSavePoint has to be defined to be used as the element type for the collection.
> Thanks,
> Sam
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
> Sent: Wednesday, May 25, 2011 10:03 PM
> To: FDO Internals Mail List
> Subject: [fdo-internals] RE: FDO RFC 61 ready for review
> Hi,
> First, the collection has to be a FdoNamedCollection to ensure the uniqueness of the names.
> Secondly, it would be more consistent with the FDO API to get this collection from the transaction object and then add to it.
> Third, about 'invalid save points': once the user has this collection it's less likely he will rollback to a invalid savepoint. Meaning also the FDO exception you indicate below will not be needed.
> In any case, the proposed RFC is missing a section where the usage is illustrated.
> My 2c.
> Dan.
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Sam Wang
> Sent: Tuesday, May 24, 2011 11:09 PM
> Hi Dan,
> I think this can be maintained internally. Once user rolls back to a specific save point, all the save points defined after it will be invalid. Thus for example, if we rolls back to save point #3, and later user rolls back to #4, an FDO exception should be thrown to indicate that save point #4 is no longer valid due to the rollback of save point #3.
> If we are to provide an API to get the list of available save points, I propose that we add an API prototype like:
> virtual FdoStringCollection* GetAvailableSavePoints() = 0;
> However my opinion is that users of this API should be aware of the order of save point definition and will not roll back to an invalid save point. So I think this API is more likely to utilize user(even if they had this utility method, they still can pass an invalid save point to rollback method), and I would regard it more like an option than necessary.
> Thanks,
> Sam
> Sent: Wednesday, May 25, 2011 10:07 AM
> Hi Sam,
> My point is that the proposed API alllows for an a arbitrary number of save points. Meaning the user needs to keep track of them. And no, "release save point" is not necessary since I assume RollBack() is doing this.
> Please let me understand: a collection of save points is actually a stack, right? If so then once the user rolls back to the save point #N (where N is the index in the stack) then all the save points with a higher number are dissolved. Therefore I believe a method to get the remaining save points is necessary.
> Thanks,
> Dan.
> ________________________________________
> From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] on behalf of Sam Wang [Sam.Wang at autodesk.com]
> Sent: Tuesday, May 24, 2011 6:44 PM
> Hi Dan,
> If you look into the RFC you will find that there is already an API proposed to roll back to a save point : FdoITransaction::RollBack(FdoString* savePointName). Do you mean that should be additional API to do something like "release save point" ?
> Thanks,
> Sam
> Sent: Tuesday, May 24, 2011 10:59 PM
> Hi,
> Shouldn't the API include a method to get back all the added save points? This would allow to programmatically rollback to a save point, I think.
> Thanks,
> Dan.
> Sent: Sunday, May 22, 2011 9:42 PM
> To: fdo-internals at lists.osgeo.org
> Subject: [fdo-internals] FDO RFC 61 ready for review
> Hi experts,
> FDO RFC 61 is now ready for review. You can find it at http://trac.osgeo.org/fdo/wiki/FDORfc61
> Thanks,
> Sam
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
