[fdo-internals] Re: insert error control properties with KingOracle
mdelsinne
mdelsinne at gmail.com
Wed Nov 30 10:40:15 EST 2011
If I do declare no geometry column, Oracle ID inserted. If there is a
geometry column no ID and no primary key.
But also why he never inserts while the other values is a simple string.
Have you any idea?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7047193.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
