[fdo-internals] RE: Create a branch for GDAL 1.9 upgrade
Trevor Wekel trevor_wekel at otxsystems.com
Fri Feb 10 18:01:46 EST 2012
Hi Greg,
Thanks for the heads up.  I will correct it.
Regards,
Trevor
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: February 10, 2012 3:41 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: Create a branch for GDAL 1.9 upgrade
Hi Trevor,
It looks like your GDAL submission into the trunk went a bit off course. You seem to have duplicated the entire sandbox tree under Thirdparty/gdal.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Wednesday, February 08, 2012 5:06 PM
That's great news!
Thanks Greg,
Trevor
Sent: February 8, 2012 7:42 AM
Hi Trevor,
You have the green light to submit your changes to the FDO Trunk.
Thanks for your efforts,
Greg
Sent: Monday, February 06, 2012 9:55 AM
Can you submit all your changes (if you have not already) to the branch? I will take a look, evaluate the impact on the current build process, and get back to you.
Now it is up to others on this list to determine if clients that wish to stay on GDAL 1.7 need to have their own branch so that when the trunk goes to 1.9, they have a stable environment from which to operate.
Greg
Sent: Friday, February 03, 2012 11:50 PM
I just wanted to give a quick update on the GDAL work.
I finally had a chance to test FDO GDAL and WMS on a 64 bit MapGuide build.  They seem to be working.  I am also in the process of validating Linux.  The GDAL and WMS FDO unit tests are returning the same results as trunk on Linux.  I am in the process of building and validating with MapGuide on Linux.
So, what's next?
Regards,
Trevor
Sent: January 28, 2012 12:38 PM
Debug64/Release64 is good for me.
Greg
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
