[fdo-internals] Sqlite provider failed on view with litterals
Romica Dascalescu Romica.Dascalescu at autodesk.com
Wed Jun 20 07:32:24 PDT 2012
Which version of FDO you are using?
I did test it on 3.8 :), however I expect 3.7 to be the same since there are no major changes between versions.
Romy.
________________________________________
From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] on behalf of Bruno Scott [bscott at geomapgis.com]
Sent: Wednesday, June 20, 2012 10:30 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] Sqlite provider failed on view with litterals
Hi Romy
I've just tried your sqlite test file in AIMS 2013
I created a new sqlite feature source with Autodesk Infrastructure Studio
2013
Test connection -> OK
Then i hit preview and refresh
I only see fc_a and fc_b
Maybe we are not using the same fdo version?
Thanks
Bruno
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sqlite-provider-failed-on-view-with-litterals-tp4982600p4982716.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
