[fdo-internals] Sqlite provider failed on view with litterals
Bruno Scott
bscott at geomapgis.com
Tue Jun 26 00:14:41 PDT 2012
Hi Romy, i have found the problem
The exact syntax for my view was
CREATE VIEW foo AS
SELECT *,* "a" *AS origin FROM a.foo
UNION
SELECT *, *"b"* AS origin FROM b.foo;
instead of
CREATE VIEW foo AS
SELECT *, *'a'* AS origin FROM a.foo
UNION
SELECT *,* 'b' *AS origin FROM b.foo;
"a" means the column a, so this raise an error
The disturding thing is when using sqlite studio, it works fine without any
warning...
Anyway, thanks a lot for your help Romy
Bruno Scott
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sqlite-provider-failed-on-view-with-litterals-tp4982600p4983832.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
