[fdo-internals] Patch for ticket 831 (Visual C++ 2010 Express
64-bit build support)
Greg Boone
greg.boone at autodesk.com
Fri May 25 23:49:12 EDT 2012
The patch looks ok.
Looking at the diff, it seems that most projects have the generate browse info flag turned off anyways. You list only a small subset where you needed to make modifications. So, I am OK with the change.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, May 25, 2012 4:58 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Patch for ticket 831 (Visual C++ 2010 Express 64-bit build support)
Hi All,
Attached is a patch to allow compilation with Visual C++ 2010 Express 64-bit.
http://trac.osgeo.org/fdo/ticket/831
My one question about this patch is the necessity of enabling browse information in certain project files. This patch disables this setting wherever it is enabled because neither Visual C++ 2010 Express or the Windows 7.1 SDK include the required 64-bit version of bscmake.exe that's needed to process browse information.
Basically, is enabling browse information necessary?
Please review. Thanks
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Patch-for-ticket-831-Visual-C-2010-Express-64-bit-build-support-tp4977062.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
