[fdo-internals] RFC 65 Implement Resampling for GDAL Provider
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 12 16:30:04 PDT 2012
On Fri, Oct 12, 2012 at 3:20 PM, Trevor Wekel
<trevor_wekel at otxsystems.com>wrote:
> Hi Frank,****
> I was not aware of VRTWarpedDataset so did not consider it initially.****
> So I took a quick look at vrtwarped.cpp. I have a question. In
> vrtwarped.cpp, the ProcessBlock() seems to cache the results of the warp
> operation (GDALCopyWords around line 1174) into each raster band. Does
> this mean that all blocks will end up being cached?****
> Trevor,
Yes, VRTWarpedDataset will always push produced tiles into the GDAL block
cache. Note that most drivers go through the block cache too.
> For FDO, we basically call a ReadNext() to suck the contents of the tile
> into a buffer supplied by the caller. The ReadNext() drives the calls to
> _getTile(). As far as I can tell, our access pattern is linear and we only
> access each tile once. If we switch to using VRTWarpedDataset, will we
> have to call ProcessBlock() for each tile? Will this end up caching all
> the blocks as we do the linear read?
In a web context, the ideal would be a long lived server which keeps
around the VRTWarpedDataset for subsequent use. I not sure how practical
that is in the FDO/MapGuide use case. In this situation caching the
blocks can help subsequent views but there might be better other layers at
which to do that.
> As an alternative to using VRTWarpedDataset, would it be ok to instantiate
> a GDALWarpOperation as a member of the FdoRfpStreamReaderByTileResample?
> Pseudo code would be something like this:****
> FdoRfpStreamReaderGdalByTileResample::FdoRfpStreamReaderGdalByTileResample()
> m_warpOp = new GDALWarpOperation();****
> FdoRfpStreamReaderGdalByTileResample::_getTile()****
> warpOptions = GDALCreateWarpOptions();****
> // populate warp options****
> m_warpOp->Initialize(warpOptions);****
> m_warpOp->WarpRegion(0,0,origXSize,origYSize);****
> This may improve the speed of the _getTile() call if a) Initialize() can
> be called more than once and b) the new GDALWarpOperation() does a lot of
> setup work
It is more likely to be the Iniitalize() that is expensive and
reinitialzing an existing WarpOperation is not a well trod path and likely
to lead to pain. I advise against it. In retrospect, sticking with your
existing approach is likely ok but you might want to get a sense of how
much time is spent in the setup code vs. the actual warping. Larger tiles
will help.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20121012/a645a159/attachment.html>
More information about the fdo-internals
