[fdo-internals] FDO Linux 64 Build
Greg Boone greg.boone at autodesk.com
Wed Oct 9 15:48:05 PDT 2013
Hi Jackie,
Linux x64 Status:
FDO API:      OK
SDF:          OK
SQLite:       OK
GDAL:         OK
WFS:          OK
WMS:          OK
MySQL:        OK. (1 of 238 tests fail. Failure seems to be non-critical. See below)
SHP:          FAIL: ~11 index cases failing. As initially reposted. Failure critical. See below.
ODBC-MySQL:   FAIL: Segmentation Violation in "OdbcMySqlFdoInsertTest.insert()."
PostGIS:      FAIL: "RDBMS: [PGRES_FATAL_ERROR] ERROR:  value "xxxx" is out of range for type smallint." Tested against Postgresql Server 8.4 and 9.2.
ODBC-Oracle:  TDB: Test environment not yet setup
Test Failure Summaries:
MySQL:
       Failure:
MySqlSchemaMgrTests.cpp:264:Assertion
Test name: 19MySqlSchemaMgrTests.testWideConstraint
pkeyClause == expectedClause
Description of Test:
Tests the creating of unique constraints that are too large for MySQL. Verifies that the MySQL provider properly truncates constraint columns to get the total size within the maximum allowed.
Check that Fails:
Verify that blob column got truncated to expected amount (1000 - total size of other columns).
SHP:
TestCommonMiscUtil.cpp:43:Assertion
Test name: 11SchemaTests.destroy_schema
File '../../TestData/Testing/Test1.idx' I/O error in context 'ShpSpatialIndex::ReadNode(ReadBuffer)': ù£§
Test name: 18SpatialFilterTests.EnvelopeIntersects
File '../../TestData/Ontario/roads.idx' I/O error in context 'ShpSpatialIndex::ReadNode(ReadBuffer)':
Test name: 18SpatialFilterTests.PerformanceTests_Roads
Test name: 13FidelityTests.nanboku
File '../../TestData/Testing/Test.idx' I/O error in context 'ShpSpatialIndex::ReadNode(ReadBuffer)':
Test name: 25FdoExpressionFunctionTest.RunAllExpFctTests
setUp() failed
IndexTests.cpp:136:Assertion
Test name: 10IndexTests.populatemin x bad
Test name: 10IndexTests.query
caught unknown exception
IndexTests.cpp:286:Assertion
Test name: 10IndexTests.check_zmin x bad
IndexTests.cpp:383:Assertion
Test name: 10IndexTests.check_limits
limits not correct
IndexTests.cpp:473:Assertion
Test name: 10IndexTests.check_remove
limits not correct
IndexTests.cpp:560:Assertion
Test name: 10IndexTests.check_defragment
limits not correct
PostGIS:
Schema XXXX has errors; cannot apply it
RDBMS: [PGRES_FATAL_ERROR] ERROR:  value "139934329470977" is out of range for type smallint
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, October 09, 2013 1:10 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] FDO Linux 64 Build
Hi Greg,
Is this work completed? Is trunk ready for 64-bit action on Linux?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/FDO-Linux-64-Build-tp5065919p5082517.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
fdo-internals at lists.osgeo.org<mailto:fdo-internals at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20131009/adf46199/attachment.html>
More information about the fdo-internals mailing list
