[fdo-internals] Please review: VS 2015 migration - open source provider
Karsten Winter
karsten.winter at autodesk.com
Wed Aug 19 04:06:22 PDT 2015
Hi all
I'm currently migrating the projects to Visual Studio 2015.
Some errors occur with the new compiler for which I would like to get a review for the solution. The 4th part is about FDO open source provider.
Shape:
Providers\SHP\Src\Provider\stdafx.h
error C2338: <hash_map> is deprecated and will be REMOVED. Please use <unordered_map>. You can define _SILENCE_STDEXT_HASH_DEPRECATION_WARNINGS to acknowledge that you have received this warning
Solution:
-> use "unordered_map" instead of "hash_map"
Providers\SHP\Src\ShpRead\ShapeFile.cpp
error C3861: 'max': identifier not found
Solution:
-> #include <algorithm>
SDF:
Providers\SDF\Src\Utils\PropertyIndex.h
Solution:
-> remove include of not required <hash_map>
Providers\SDF\Src\Provider\BinaryReader.h
Providers\SDF\Src\Provider\ExInfoDb.h
Providers\SDF\Src\Provider\SchemaDb.h
Providers\SDF\Src\Provider\SdfConnection.cpp
Providers\SDF\Src\Provider\SdfConnection.h
Providers\SDF\Src\Provider\SdfExtHashMap.h
Providers\SDF\Src\Provider\SdfSchemaMergeContext.cpp
Providers\SDF\Src\Provider\SdfSchemaMergeContext.h
Providers\SDF\Src\Provider\TableReformatter.h
Solution:
-> use "unordered_map" instead of "hash_map" in several classes
WFS:
Utilities\OWS\stdafx.h
Solution:
-> remove include of no required <hash_map>
ArcSDE:
Providers\ArcSDE\Src\Provider\stdafx.h
Solution:
SQLite:
Providers\sqlite\src\spatialindex\sltgeomutils.h
error C2039: 'min': is not a member of 'std'
Solution:
providers\sqlite\src\provider\stringutil.h
error C2039: 'max': is not a member of 'std'
Solution:
Best regards
Karsten
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20150819/d3dc2fd8/attachment.html>
Type: application/octet-stream
Desc: Providers_Shape.patch
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20150819/d3dc2fd8/attachment.obj>
Desc: Providers_SDF.patch
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20150819/d3dc2fd8/attachment-0001.obj>
Desc: Utilities_OWS_stdafx.h.patch
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20150819/d3dc2fd8/attachment-0002.obj>
Desc: Providers_ArcSDE_Src_Provider_stdafx.h.patch
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20150819/d3dc2fd8/attachment-0003.obj>
Desc: Providers_SQLite.patch
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20150819/d3dc2fd8/attachment-0004.obj>
More information about the fdo-internals
