[fdo-internals] Ticket #918
Johan Van de Wauw
johan.vandewauw at gmail.com
Wed May 25 13:55:39 PDT 2016
I did a quick check and the CMakelists.txt in the same dir also misses a file.
On Tue, May 24, 2016 at 3:09 PM, Johan Van de Wauw
<johan.vandewauw at gmail.com> wrote:
> correct place would be LDFLAGS . You can add it when using ./configure
> or add it in configure.in
> so
> export LDFLAGS=-z defs
> ./configure
> or add
> LDFLAGS +=-z defs
> to configure.in
> I'm on a conference - so I haven't tested this, but should work.
> Kind Regards,
> Johan
> On Tue, May 24, 2016 at 2:22 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> Hi Johan,
>> Is this something you would stick into CXXFLAGS of configure.in?
>> - Jackie
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/Ticket-918-tp5267817p5267956.html
>> Sent from the FDO Internals mailing list archive at Nabble.com.
>> fdo-internals mailing list
>> fdo-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20160525/8881854b/attachment.bin>
More information about the fdo-internals
