[fdo-internals] Migrating to Git from Subversion
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue May 26 05:11:34 PDT 2020
Hi Martin-Louis, Jackie,
Why don't you just file a ticket for this request at
https://trac.osgeo.org/osgeo  to include the repository inside
https://github.com/OSGeo as you mentioned.  Use the "Systems Admin"
component on the ticket.  It can't hurt to try.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://gatewaygeo.com/
On 2020-05-26 8:47 a.m., Jackie Ng wrote:
> Hello Martin-Louis,
> I'm cross-posting this to multiple mailing lists, hope this discussion
> doesn't explode into spaghetti!!
> There is no official git mirror. Un-officially, I have made some
> attempts to create git mirrors:
> https://github.com/jumpinjackie/cs-map
> https://github.com/jumpinjackie/fdo
> https://github.com/jumpinjackie/mapguide
> https://github.com/jumpinjackie/fusion
> But these repos are many months out of sync as I've stopped my personal
> AWS EC2 instance that was doing the mirroring.
> The problem with git mirroring right now is:
>   1. MapGuide has svn:external links to CS-Map and Fusion repos. If we
> mirror MapGuide to git, we have to mirror CS-Map and Fusion to git as
> well at a bare minimum and translate svn:external references to their
> git equivalents (submodules?)
>      1.1. CS-Map has really large dictionary data files that break
> github's repo file limits forcing me to use git-lfs for storing these
> files. But git-lfs storage is a severely restricted service on GitHub's
> free tier. Last I checked, I used up my free tier git-lfs quota just
> doing a single force push of this repository!
>      1.2. Git submodules are hell in my personal experience, but not
> using submodules require developers having to set up CS-Map and Fusion
> source trees manually within MapGuide's source tree.
>   2. I have not been successful in coming up with a svn -> git
> conversion scheme that allows commits or merged PRs in github to easily
> flow back into SVN. This is probably because I've been cleaning out
> historical baggage (eg. Commits of source/binary tarballs in
> LinuxApt/Installer) as part of the svn -> git conversion process with
> bfg repo cleaner so a git clone is not so bloated. But even on pristine
> converted git repos I could not succesfully get git commits to flow back
> to its svn counterpart.
> Now suppose we give up the notion of trying to have a bidirectional svn
> <-> git mirror and just bite the bullet and do a full blown one-way
> migration (leaving the svn repos behind, and not have to worry about #2
> above). Then the problems become project management related.
>   a) You preferably want buy-in from all PSCs involved in this one-way
> migration, otherwise you're having to setup up and maintain
> "un-official" git mirrors of all MapGuide upstream repos.
>   b) For FDO particularly, I know Autodesk keeps maintaining a 4.2
> commercial branch that I like to selectively merge useful commits from
> into OS trunk and other OS branches on a semi-regular basis. One-way
> migrating FDO to git would need Autodesk buy-in to continue their
> maintenance on the migrated git repository.
>   c) For CS-Map particularly, the dictionary file size limitations have
> to be addressed. Preferably in a way that does not involve a paid
> git-lfs storage plan.
>   d) There's organizational questions around whether these migrated
> repos should fall under the OSGeo github org or another github org.
>   e) There's also setup/integration questions around OSGeo CLAs in these
> repos as being an OSGeo project, we could not accept external pull
> requests without confirmation (strongly-and-preferably automated) that
> the submitter has signed and submitted an OSGeo CLA
> Pardon the preceding wall of text, I had thoughts about git migration
> brewing in my mind for a while but had not put anything to words since
> nobody else had posed the git migration question until now.
> Since you are also from Autodesk, it would probably be more effective to
> for you to start this conversation with your colleagues who still commit
> changes to these various projects "from within" to seek some consensus
> from the Autodesk side as to whether it is worth moving to github in
> addition to addressing some/all of the points I've raised. I wouldn't
> want to go all-in on a one-way git migration only to find Autodesk still
> making commits to the original SVN repos afterwards.
> - Jackie
> http://themapguyde.blogspot.com
>     Hi!
>     Is there a Git mirror for the MapGuide repo in Subversion athttps://svn.osgeo.org/?  It would be great if this repository was onhttps://github.com/OSGeo,  for instance.
>     Martin-Louis Bright
>     Senior Software Engineer
>     www.autodesk.com  <http://www.autodesk.com><http://www.autodesk.com/>
>     [signature_1744242845]
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20200522/ef6a392e/attachment.html>
>     A non-text attachment was scrubbed...
>     Type: image/png
>     Desc: image001.png
>     URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20200522/ef6a392e/attachment.png>
More information about the fdo-internals mailing list
