[fdo-trac] #61: Necessary changes to Schema Manager
FDO trac_fdo at osgeo.org
Thu Apr 12 16:10:42 EDT 2007
 Reporter:  thomasknoell      |         Owner:  thomasknoell
     Type:  defect            |        Status:  closed
 Priority:  major             |     Milestone:  3.3.0
Component:  GenericRdbms API  |       Version:  3.2.0
 Severity:  2                 |    Resolution:  fixed
 Keywords:                    |   External_id:
Changes (by thomasknoell):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 The fix involves changes to the following files:
 Modified: \Providers\GenericRdbms\Src\UnitTest\Common\UnitTestUtil.cpp
 Modified: \Utilities\SchemaMgr\Inc\Sm\Lp\Schema.h
 Modified: \Utilities\SchemaMgr\Inc\Sm\Lp\SchemaCollection.h
 Modified: \Utilities\SchemaMgr\Src\Sm\Lp\Schema.cpp
 Modified: \Utilities\SchemaMgr\Src\Sm\Lp\SchemaCollection.cpp
 Modified: \Utilities\SchemaMgr\Src\Sm\Ph\DbObject.cpp
 All changes were also ported to the trunk.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/61#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
