[fdo-trac] #65: GDAL: Connection RefCount incremented for
Internal woker objects
trac_fdo at osgeo.org
Wed Apr 25 16:37:49 EDT 2007
#65: GDAL: Connection RefCount incremented for Internal woker objects
Reporter: gregboone | Owner: gregboone
Type: defect | Status: assigned
Priority: major | Milestone: 3.2.2
Component: GDAL Provider | Version: 3.2.2
Severity: 1 | Resolution:
Keywords: refcount, addref | External_id:
Old description:
> When the GDAL provider connection is created and Open() is called, the
> resulting !RefCount should be 1. With the GDAL provider the !RefCount is
> incremented to 3. These additional increments are caused during the Open
> process as the connection object is passed via method parameters, to
> several internal worker objects (including !FdoRfpClassData and
> !FdoRfpGeoBandRaster) who in turn call !AddRef on the connection. When
> dealing with internal worker objects, whoose lifespan is guaranteed to be
> the lifespan to the connection, these types of object should only hold
> soft references to the connection object so that a circular dependency
> does not occur. The solution to this issue is to not !AddRef the
> connection when storing the pointer as class data.
New description:
process as the connection object is passed, via method parameters, to
Ticket URL: <http://trac.osgeo.org/fdo/ticket/65#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
