[fdo-trac] #65: GDAL: Connection RefCount incremented for internal worker objects
FDO trac_fdo at osgeo.org
Wed Apr 25 16:56:34 EDT 2007
 Reporter:  gregboone         |         Owner:  gregboone
     Type:  defect            |        Status:  assigned
 Priority:  major             |     Milestone:  3.2.2
Component:  GDAL Provider     |       Version:  3.2.2
 Severity:  1                 |    Resolution:
 Keywords:  refcount, addref  |   External_id:
Old description:
> When the GDAL provider connection is created and Open() is called, the
> resulting !RefCount should be 1. With the GDAL provider the !RefCount is
> incremented to 3. These additional increments are caused during the Open
> process as the connection object is passed, via method parameters, to
> several internal worker objects (including !FdoRfpClassData and
> !FdoRfpGeoBandRaster) who in turn call !AddRef on the connection. When
> dealing with internal worker objects, whoose lifespan is guaranteed to be
> the lifespan to the connection, these types of object should only hold
> soft references to the connection object so that a circular dependency
> does not occur. The solution to this issue is to not !AddRef the
> connection when storing the connection pointer as class data.
New description:
 dealing with internal worker objects, whose lifespan is guaranteed to be
Ticket URL: <http://trac.osgeo.org/fdo/ticket/65#comment:5>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
