[fdo-trac] #103: Add x64 Configurations to the FDO API and SDF
Provider Windows Build Scripts
trac_fdo at osgeo.org
Wed Aug 15 15:00:19 EDT 2007
#103: Add x64 Configurations to the FDO API and SDF Provider Windows Build
Scripts
Reporter: gregboone | Owner: gregboone
Type: enhancement | Status: new
Priority: minor | Milestone: 3.3.0
Component: FDO API | Version: 3.3.0
Severity: 2 | Keywords: Win64;x64;Build
External_id: |
This submission will add Win64 support to the OSGeo FDO API and the OSGeo
SDF
Provider. A new platform configuration 'x64' has been added to all
relevant
windows project and solution files. Developers can now either choose to
build the
standard 'Win32' Debug and Release configurations or the 'x64' Debug and
release
configurations.
In the process of adding the 'x64' configurations, several project files
were
cleaned up to remove stale configurations that were no longer being
maintained
or used. The general goal is to have only a Debug and a Release
configuration
for each platform supported.
As a part of the x64 changes, several source files were changed to fix
warnings
or resolve build issues. Many of these changes happened in the Third-party
directory. If updates are to be made to projects in the Third-party from
the
original posted source on the originating sites, care should be made to
preserve
the x64 changes.
In addition of the project file and source file changes, the Open Source
build
scripts were also updated to allow the x64 configurations to be built
through a
command line process. If an x64 configuration is needed, use the -p option
to
specify the platform that needs to be built.
Here are the parameters to the new build.bat script.
build.bat [-h]
[-o=OutFolder]
[-c=BuildType]
[-p=PlatformType]
[-a=Action]
[-w=WithModule]
[-d=BuildDocs]
[-py=BuildPythonWrappers]
Help: -h[elp]
OutFolder: -o[utpath]=destination folder for binaries
BuildType: -c[onfig]=release(default), debug
PlatformType: -p[latform]=win32(default), x64
Action: -a[ction]=build(default),
buildinstall,
install,
clean
BuildDocs: -d[ocs]=skip(default), build
BuildPythonWrappers: -py[thon]=skip(default), build
WithModule: -w[ith]=all(default),
fdo,
providers,
shp,
sdf,
wfs,
wms,
arcsde,
odbc,
mysql,
gdal
* NOTE that there are still a few outstanding issues with the x64 builds
1) The build scripts cannot resolve the INCLUDE path settings hen using
the amd64 compiler
2) The stampver scripts are not recognizing that the 64bit binaries have
resources attached to them. Therefore, stamping the 64bit binaries has
been temporarily disabled.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/103>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
