[fdo-trac] #109: Extract FDO Provider Test Data Into Separate tar Files.
FDO trac_fdo at osgeo.org
Wed Aug 29 13:45:18 EDT 2007
   Reporter:  gregboone  |       Owner:  gregboone
       Type:  defect     |      Status:  new
   Priority:  minor      |   Milestone:  3.3.0
  Component:  General    |     Version:  3.3.0
   Severity:  3          |    Keywords:
External_id:             |
 This defect is being opened in order to extract the test data for the
 GDAL, SHP, SDF and ArcSDE OSGeo providers into separate tar.gz files. This
 will reduce the respective sizes of the tar files containing the source
 code for each provider, and will allow downloads to proceed more quickly.
 If a user wishes to run the unit tests that use TestData, the testdata tar
 file for the provider will have to be retrieved as well.
 The names of the new tar files will be as follows:
         fdoarcsde-testdata-3.3.0_SXXX.zip
         fdogdal-testdata-3.3.0_SXXX.zip
         fdosdf-testdata-3.3.0_SXXX.zip
         fdoshp-testdata-3.3.0_SXXX.zip
Ticket URL: <http://trac.osgeo.org/fdo/ticket/109>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
