[fdo-trac] #110: Invalid URL Encoding in WMS Provider
trac_fdo at osgeo.org
Wed Aug 29 15:37:05 EDT 2007
Reporter: gregboone | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: FDO API | Version: 3.2.0
Severity: 3 | Resolution:
Keywords: | External_id:
Old description:
> Doesn't Work (FDO Output):
> http://demo.ermapper.com/ecwp/ecw_wms.dll?skdemo?&version=1%2E1%2E1&service=WMS&REQUEST=GetMap&LAYERS=ERIC%5FCLIP&STYLES=&CRS=EPSG%3A26913&SRS=EPSG%3A26913&FORMAT=image%2Fpng&BBOX=318504%2E021168%2C5405015%2E092878%2C556941%2E817003%2C5788873%2E742216&HEIGHT=586&WIDTH=364&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF%20HTTP/1.1
> Works (Remove URL encoding)
> http://demo.ermapper.com/ecwp/ecw_wms.dll?skdemo?&version=1.1.1&service=WMS&REQUEST=GetMap&LAYERS=ERIC_CLIP&STYLES=&CRS=EPSG:26913&SRS=EPSG:26913&FORMAT=image/png&BBOX=318504.021168,5405015.092878,556941.817003,5788873.742216&HEIGHT=586&WIDTH=364&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF
> WMS 1.1.1 Spec
> 6.2.1 Reserved characters in HTTP GET URLs
> The URL specification [IETF RFC 2396] reserves particular characters as
> significant and requires that these be escaped when they might conflict
> with their defined usage. The present WMS specification explicitly
> reserves several of these characters for use in the query portion of HTTP
> GET requests. When the characters "?", "&", "=", "/", ":" and "," appear
> in one of the roles defined in Table 1, they are to appear literally in
> the URL. When such characters appear elsewhere (for example, in the value
> of a parameter), they are to be encoded as defined in [IETF RFC 2396].
> Table 1 Reserved Characters in HTTP GET Query
> Character...Reserved Usage
> ? Separator indicating start of query string.
> & Separator between parameters in query string.
> = Separator between name and value of parameter.
> / Separator between MIME type and subtype in format parameter value.
> : Separator between Namespace and Identifier in SRS parameter value.
> , Separator between individual values in list-oriented parameters.
> Alternative (per WMS spec - does not work - handcrafted)
> http://demo.ermapper.com/ecwp/ecw_wms.dll?skdemo?&version=1%2E1%2E1&service=WMS&REQUEST=GetMap&LAYERS=ERIC%5FCLIP&STYLES=&CRS=EPSG%3A26913&SRS=EPSG:26913&FORMAT=image/png&BBOX=318504%2E021168,5405015%2E092878,556941%2E817003,5788873%2E742216&HEIGHT=586&WIDTH=364&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF%20HTTP/1.1
> Alternative (works - found by changing encoding by hand one character at
> a time)
> http://demo.ermapper.com/ecwp/ecw_wms.dll?skdemo?&version=1.1.1&service=WMS&REQUEST=GetMap&LAYERS=ERIC%5FCLIP&STYLES=&CRS=EPSG%3A26913&SRS=EPSG:26913&FORMAT=image/png&BBOX=318504.021168,5405015.092878,556941.817003,5788873.742216&HEIGHT=586&WIDTH=364&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF%20HTTP/1.1
> Possible Conclusions:
> ERMapper does not accept input "version=1%2E1%2E1"2E for "version=1.1.1"
> as specified in WMS 1.1.1 (section 6.2.1)
> ERMapper does not seem to accept "%2E" as "." as specified in WMS 1.1.1
> (section 6.2.1)
> FDO outputs "SRS=EPSG%3A26913" instead of "SRS=EPSG:26913" as specified
> FDO outputs
> "BOX=318504%2E021168%2C5405015%2E092878%2C556941%2E817003%2C5788873%2E742216"
> instead of
> "BBOX=318504%2E021168,5405015%2E092878,556941%2E817003,5788873%2E742216"
> It appears that there is confusion about whether "." is a reserved
> character...it is not according to IETF RFC 2396
New description:
WMS 1.1.1 Spec
Alternative (works - found by changing encoding by hand one character at a
time)
(section 6.2.1)
FDO outputs "SRS=EPSG%3A26913" instead of "SRS=EPSG:26913" as specified in
FDO outputs
instead of
Ticket URL: <http://trac.osgeo.org/fdo/ticket/110#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
