[fdo-trac] #188: OGR and PostGIS providers not working under MapGuide on Ubuntu 7.10
FDO trac_fdo at osgeo.org
Tue Dec 4 18:35:22 EST 2007
 Reporter:  jbirch        |         Owner:  gregboone
     Type:  defect        |        Status:  new
 Priority:  major         |     Milestone:  3.3.0
Component:  Build System  |       Version:  3.3.0
 Severity:  3             |    Resolution:
 Keywords:                |   External_id:
Changes (by jbirch):
 * cc: mloskot (added)
Comment:
 OK, that's odd.  I see the missing dependancy, but...
 I am able to successfully test the conenction to PostGIS source via Studio
 anyways.  Perhaps I have a system component (libcrypt, postgresql-dev)
 installed that Jo doesn't.
 However, when I save the connection, the MapGuide server crashes and I get
 the following error:
 <2007-12-04T14:45:10>                   Administrator
  Error: An exception occurred in FDO component.
         The execution of GetSpatialContextsCommand command failed.
  StackTrace:
   - MgFeatureServiceHandler.ProcessOperation line 83 file
 FeatureServiceHandler.cpp
   - MgOpGetSpatialContexts.Execute line 108 file OpGetSpatialContexts.cpp
   - MgServerGetSpatialContexts.GetSpatialContexts line 106 file
 ServerGetSpatialContexts.cpp    An exception occurred in FDO component.
 This may be because I'm not connected to a PostGIS server, but just a
 straight PostgreSQL server.  I'll have to install the spatial extensions
 and see what happens.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/188#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
