[fdo-trac] #193: UnitTests on MySQL 5.1.22-rc-community - Run: 228
Failures: 43 Errors: 20
trac_fdo at osgeo.org
Mon Dec 10 03:21:40 EST 2007
#193: UnitTests on MySQL 5.1.22-rc-community - Run: 228 Failures: 43
Errors: 20
Reporter: based | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: MySQL Provider | Version: 3.3.0
Severity: 3 | Keywords:
External_id: |
Test Results with MySQL 5.1.22-rc-community:
Context:
OS: Windows XP SP2.
At the same time uploading a schema and data in the MySQL database
(.\ upload_schema.sql).
To get the UnitTest working, I copied and renamed the libMySQL.dll to the
mysql unit test directory.
Run: 228 Failures: 43 Errors: 20
1) test: MySqlFdoApplySchemaTest.TestSchema (F) line: 1778
.\Common\FdoApplySch
maTest.cpp
"pMessage && wcscmp( pMessage, L"MetaClass schema F_MetaClass is read-
only; ca
not modify it ") == 0"
2) test: MySqlFdoApplySchemaTest.TestOverrides (F) line: 1187
.\Common\UnitTest
til.cpp
"RDBMS: Invalid default value for 'featid' ... Schema ForeignBased has
errors;
cannot apply it "
3) test: MySqlFdoApplySchemaTest.TestOverrideErrors (F) line: 1568
.\Common\Uni
TestUtil.cpp
"Output file MySql_17556_MySql_17556_apply_schema_overrides_err1.txt
differs f
om expected output file apply_schema_overrides_err1_master.txt"
4) test: MySqlFdoApplySchemaTest.TestLT (F) line: 1187
.\Common\UnitTestUtil.cp
"RDBMS: Data truncation error."
5) test: MySqlFdoApplySchemaTest.TestConfigDoc (F) line: 1187
.\Common\UnitTest
til.cpp
"RDBMS: Data truncation error. ... Schema Acad has errors; cannot apply
it "
6) test: MySqlFdoCapabilityTest.Connection (F) line: 50
.\Src\TestCommonMiscUti
.cpp
"RDBMS: Data truncation error. [RDBMS: Data truncation error.]"
7) test: MySqlFdoConnectTest.query (F) line: 50
.\Src\TestCommonMiscUtil.cpp
8) test: MySqlFdoDeleteTest.FeatureDelete (F) line: 1187
pp
9) test: MySqlFdoImportExportTest.Test1 (F) line: 1568
"Output file MySql_17556_impexp_err1.txt differs from expected output
file imp
xp_err1_master.txt"
10) test: MySqlFdoImportExportTest.Test5_6_7 (F) line: 1568
.\Common\UnitTestUt
l.cpp
"Output file MySql_17556_impexp_err7.txt differs from expected output
file imp
xp_err7_master.txt"
11) test: MySqlFdoInsertTest.insert (F) line: 50
12) test: MySqlFdoInsertTest.insertEmptyProps (F) line: 50
til.cpp
13) test: MySqlFdoInsertTest.insert3 (F) line: 1187
.\Common\UnitTestUtil.cpp
14) test: MySqlFdoInsertTest.insertBoundary (F) line: 1187
.cpp
15) test: MySqlFdoInsertTest.insertDate (F) line: 1187
16) test: MySqlFdoInsertTest.smartPointerInsert (F) line: 50
.\Src\TestCommonMi
cUtil.cpp
17) test: MySqlFdoInsertTest.insertFlushTest (F) line: 50
il.cpp
18) test: MySqlFdoInsertTest.insertAutoGen (F) line: 50
.cpp
19) test: MySqlFdoInsertTest.insertNonExistProp (F) line: 1954
.\Common\FdoInse
tTest.cpp
"wcsncmp(ex->GetExceptionMessage(), L"Property 'GEOMETRY' not found", 29)
== 0
20) test: MySqlFdoMultiThreadTest.QueryTest (F) line: 50
l.cpp
21) test: MySqlFdoMultiThreadTest.InsertTest (F) line: 50
il.cpp
22) test: MySqlFdoMultiThreadTest.CombinationTest (F) line: 50
.\Src\TestCommon
iscUtil.cpp
23) test: MySqlFdoSchemaRollbackTest.Test_nnyn (F) line: 1187
.\Common\UnitTest
til.cpp
it "
24) test: MySqlFdoSchemaTest.Test_Defect802102 (F) line: 1187
.\Common\UnitTest
til.cpp
"Unable to load the FDO Provider: Le module spÚcifiÚ est introuvable.
25) test: MySqlFdoSelectTest.non_feature_subset_query (F) line: 50
.\Src\TestCo
monMiscUtil.cpp
26) test: MySqlFdoSelectTest.feature_subset_query (F) line: 50
.\Src\TestCommon
iscUtil.cpp
27) test: MySqlFdoSelectTest.feature_query (F) line: 50
.cpp
28) test: MySqlFdoSelectTest.non_feature_query (F) line: 50
.\Src\TestCommonMis
Util.cpp
29) test: MySqlFdoSelectTest.spatial_query (F) line: 50
.cpp
30) test: MySqlFdoSelectTest.spatial_query_defect792377 (E)
"caught unknown exception"
31) test: MySqlFdoSelectTest.spatial_query_defect880310 (E)
32) test: MySqlFdoSelectTest.feature_object_query (F) line: 50
.\Src\TestCommon
iscUtil.cpp
33) test: MySqlFdoSelectTest.feature_select_obj_distinct (F) line: 50
.\Src\Tes
CommonMiscUtil.cpp
"RDBMS: Data truncation error. [RDBMS: Data truncation error.] [RDBMS:
Data tr
ncation error.]"
34) test: MySqlFdoSelectTest.feature_geom_query (F) line: 50
.\Src\TestCommonMi
cUtil.cpp
35) test: MySqlFdoSelectTest.concurrent_select (F) line: 50
.\Src\TestCommonMis
Util.cpp
36) test: MySqlFdoSelectTest._secondComputedIdTest (F) line: 50
.\Src\TestCommo
MiscUtil.cpp
37) test: MySqlFdoUpdateTest.Update (F) line: 50
38) test: MySqlFdoUpdateTest.UpdateAttributesOnly (F) line: 50
.\Src\TestCommon
iscUtil.cpp
39) test: MySqlFdoUpdateTest.UpdateObjectProperty (F) line: 50
.\Src\TestCommon
iscUtil.cpp
40) test: MySqlFdoUpdateTest.FdoUpdateTestTypes (F) line: 50
.\Src\TestCommonMi
cUtil.cpp
41) test: MySqlFdoUpdateTest.UpdateMultiIdFeatureClass (F) line: 1187
.\Common\
nitTestUtil.cpp
"RDBMS: Data truncation error. ... RDBMS: Data truncation error."
42) test: MySqlFdoUpdateTest.UpdateNlsIdFeatureClass (F) line: 1187
.\Common\Un
tTestUtil.cpp
43) test: MySqlFdoUpdateTest.testForeignDataStore (F) line: 1187
.\Common\UnitT
stUtil.cpp
44) test: MySqlSchemaMgrTests.testGenDefault (F) line: 1187
.\Common\UnitTestUt
l.cpp
45) test: MySqlSchemaMgrTests.testGenKeys (F) line: 1187
pp
46) test: MySqlFdoAdvancedSelectTest.compIdentFilterTest (E)
"setUp() failed"
47) test: MySqlFdoAdvancedSelectTest.compIdentPropertyTest (E)
"setUp() failed"
48) test: MySqlFdoAdvancedSelectTest.orderByTest (E)
"setUp() failed"
49) test: MySqlFdoAdvancedSelectTest.groupByTest (E)
"setUp() failed"
50) test: MySqlFdoAdvancedSelectTest.functionTest (E)
"setUp() failed"
51) test: MySqlFdoAdvancedSelectTest.selectDistinctTest (E)
"setUp() failed"
52) test: MySqlFdoAdvancedSelectTest.TestDefect779194 (E)
"setUp() failed"
53) test: MySqlFdoAdvancedSelectTest.TestDefect785616 (E)
"setUp() failed"
54) test: MySqlFdoAdvancedSelectTest.getDataTypeTest (E)
"setUp() failed"
55) test: MySqlFdoAdvancedSelectTest.groupByorderByTest (E)
"setUp() failed"
56) test:
MySqlFdoAdvancedSelectTest.checkDataReaderContentOnSelAggRequestWithA
grFunction (E)
"setUp() failed"
57) test:
MySqlFdoAdvancedSelectTest.checkDataReaderContentOnSelAggRequestWithN
mCharFunction (E)
"setUp() failed"
58) test:
MySqlFdoAdvancedSelectTest.checkFeatureReaderContentOnSelRequestWithA
grFunction (E)
"setUp() failed"
59) test:
MySqlFdoAdvancedSelectTest.checkFeatureReaderContentOnSelRequestWithN
mCharFunction (E)
"setUp() failed"
60) test: MySqlFdoAdvancedSelectTest.TestMaxBoolProperty (E)
"setUp() failed"
61) test: MySqlFdoAdvancedSelectTest.TestUpperDateProperty (E)
"setUp() failed"
62) test: MySqlFdoAdvancedSelectTest.TestCeillInt64Property (E)
"setUp() failed"
63) test: MySqlFdoAdvancedSelectTest.TestLowerOnStringProperty (E)
"setUp() failed"
Ticket URL: <http://trac.osgeo.org/fdo/ticket/193>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
