[fdo-trac] #203: GetSupportedCRSNames should filter out the CRS without validated bounding box
FDO trac_fdo at osgeo.org
Fri Dec 21 03:08:51 EST 2007
box
   Reporter:  yangm         |       Owner:  yangm
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.3.0
  Component:  WMS Provider  |     Version:  3.2.0
   Severity:  3             |    Keywords:
External_id:                |
 The spatial context collection contains all the supported CS and
 boundingbox for each CS. But the bounding box for each CS is the union of
 each small bounding box from different layer which also support the same
 CS.
 But this will cause a defect for the following situation:
 The root layer support CS: CS-1, CS-1, but without specific boundingbox
 for each CS.
 There is child layer: Layer1, supporting CS-1, with its small bounding
 box;
 child layer: Layer2, supportting CS-2, with its smail bounding box;
 For the above example, the supported CS list for layer2 should only have
 CS-2, because there is no valid bounding box for CS-1 though the CS-1 is
 supported by it from WMS standard.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/203>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
