[fdo-trac] #13: Merging defect fixes from branch 3.2.x to the trunk
FDO trac_fdo at osgeo.org
Tue Feb 20 15:33:48 EST 2007
   Reporter:  Badreddine.Karoui at autodesk.com  |       Owner:  badreddinekaroui
       Type:  defect                          |      Status:  new
   Priority:  major                           |   Milestone:  3.3.0
  Component:  SDF Provider                    |     Version:  3.2.0
   Severity:  3                               |    Keywords:
External_id:                                  |
 The following fixes need to be merged from branch 3.2.x to the trunck:
 1) Iterating through all the features of a large SDF file causes a
 significant loss of the system available memory. This is due to the system
 disk cache which tend to use all the memory it can get.
 The fix is to remove the random access option when opening the SDF file.
 That reduced the memory used by the disk cache to a reasonable amount and
 did not impact the performance of the SDF provider(it actually helped a
 bit).
 1) An Rtree rebalancing issue where the root node get deleted and the new
 root node is not persisted.
Ticket URL: <http://trac.osgeo.org/trac/fdo/ticket/13>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
