[fdo-trac] #15: Missing Raster Extents
FDO trac_fdo at osgeo.org
Wed Feb 21 00:20:30 EST 2007
   Reporter:  warmerdam      |       Owner:  warmerdam
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.3.0
  Component:  GDAL Provider  |     Version:  3.2.0
   Severity:  2              |    Keywords:
External_id:                 |
 MapGuide does not know the default extents for raster data coming from the
 GDAL raster
 provider.
 Traian reports:
 You need to make sure that your FdoISpatialContextReader::GetExtent()
 returns correct extents for the rasters you are connected to. If it
 already does that, then we would have to dig deeper, but I think that
 should be sufficient.
 Fyi, this is what I am using in the OGR provider, and it works most of the
 time:
 FdoByteArray* OgrSpatialContextReader::GetExtent()
 OGREnvelope e;
 /*OGRErr err =*/
 m_connection->GetOGRDataSource()->GetLayer(m_nIndex)->GetExtent(&e, TRUE);
 //generate FGF polygon and return as refcounted byte array
 double coords[10];
 coords[0] = e.MinX;
 coords[1] = e.MinY;
 coords[2] = e.MaxX;
 coords[3] = e.MinY;
 coords[4] = e.MaxX;
 coords[5] = e.MaxY;
 coords[6] = e.MinX;
 coords[7] = e.MaxY;
 coords[8] = e.MinX;
 coords[9] = e.MinY;
 FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance();
 FdoPtr<FdoILinearRing> lr = gf->CreateLinearRing(FdoDimensionality_XY, 10,
 coords);
 FdoPtr<FdoIPolygon> fgfgeom = gf->CreatePolygon(lr, NULL);
 return gf->GetFgf(fgfgeom);
Ticket URL: <http://trac.osgeo.org/fdo/ticket/15>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
