[fdo-trac] #22: Reading large config file is slow.
    trac_fdo at osgeo.org
    Thu Mar  1 10:59:54 EST 2007
 Reporter:  brentrobinson  |         Owner:  brentrobinson
     Type:  enhancement    |        Status:  assigned
 Priority:  major          |     Milestone:  3.2.2
Component:  FDO API        |       Version:  3.2.2
 Severity:  2              |    Resolution:
 Keywords:                 |   External_id:
Comment (by brentrobinson):
 Revision: 2617
 Author: brentrobinson
 Date: 10:58:12 AM, Thursday, March 01, 2007
 Message:
 Ticket #22: Improved performance for reading from XML, by reducing number
 of memory allocations and string copies.
 Modified : /trunk/Fdo/UnitTest/CommonTest.cpp
 Modified : /trunk/Fdo/Unmanaged/Common.vcproj
 Modified : /trunk/Fdo/Unmanaged/Inc/Common/DictionaryElement.h
 Modified : /trunk/Fdo/Unmanaged/Inc/Common/NamedCollection.h
 Modified : /trunk/Fdo/Unmanaged/Inc/Common/Xml/Attribute.h
 Added : /trunk/Fdo/Unmanaged/Src/Common/CommonInternal.cpp
 Added : /trunk/Fdo/Unmanaged/Src/Common/CommonInternal.h
 Modified : /trunk/Fdo/Unmanaged/Src/Common/Makefile.am
 Modified : /trunk/Fdo/Unmanaged/Src/Common/Xml/ReaderXrcs.cpp
 Modified : /trunk/Fdo/Unmanaged/Src/Common/Xml/ReaderXrcs.h
Ticket URL: <http://trac.osgeo.org/fdo/ticket/22#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
