[fdo-trac] #5: GDAL: Update FDO Thirdparty to latest GDAL Source
FDO trac_fdo at osgeo.org
Mon Mar 5 12:08:22 EST 2007
 Reporter:  gregboone              |         Owner:  gregboone
     Type:  enhancement            |        Status:  assigned
 Priority:  minor                  |     Milestone:  3.3.0
Component:  Thirdparty Components  |       Version:
 Severity:  2                      |    Resolution:
 Keywords:  GDAL WMS               |   External_id:
Comment (by gregboone):
 Author: gregboone
 Date: 2007-03-04 13:09:51 -0500 (Sun, 04 Mar 2007) New Revisions: 2626-
 2638
 This submission updates the default version of GDAL in Thirdparty to
 1.4.x. The GDAL source files have been moved from Thirdparty/GDAL1.3 ->
 Thirdparty/gdal. The Windows and Linux build process has been updated to
 reflect the new GDAL source code location and content.
 This submission introduces a new $FDOGDAL variable into the FDO build
 process (Similar to $FDO). $FDOGDAL identifies where the GDAL installed
 binaries and header files are located.
 On Windows, the default value of $FDOGDAL would point to
 trunk/Thirdparty/gdal and would pull header files and libraries from…
 trunk/Thirdparty/gdal/bin
 trunk/Thirdparty/gdal/lib
 trunk/Thirdparty/gdal/include
 On Linux, the default value of $FDOGDAL would point to /usr/local and
 /usr/local/lib
 /usr/local/include
 With the introduction of this variable, users now have the option to not
 build GDAL in trunk/Thirdparty/gdal and instead link against an installed
 version of GDAL that is different from the version included in
 /trunk/Thirdparty/gdal. The user can identify the location of their custom
 install by changing the value of the $FDOGDAL variable to point to their
 GDAL installation. This approach is similar (but not identical) to how we
 handle ODBC and MYSQL SDK components.
 NOTE: By default, the trunk/build_thirdparty.sh and
 trunk/build_thirdparty.bat scripts build and install GDAL.
 The following files were added/removed/modified
 Added:
    trunk/Thirdparty/Thirdparty_gdal.sh
    trunk/Thirdparty/Thirdparty_gdal.sln
 Removed:
    trunk/Thirdparty/GDAL1.3/
    trunk/build_linux.sh
    trunk/setenvironment.bat
    trunk/setenvironment.sh
    trunk/Thirdparty/build.bat
    trunk/Thirdparty/Makefile.am
    trunk/Thirdparty/Thirdparty.sh
    trunk/Thirdparty/Thirdparty.sln
    trunk/Thirdparty/Thirdparty_wms.sh
    trunk/Thirdparty/Thirdparty_wms.sln
    trunk/Providers/GDAL/configure
    trunk/Providers/GDAL/configure.in
    trunk/Providers/GDAL/config.status
    trunk/Providers/GDAL/Src/Makefile.am
    trunk/Providers/GDAL/Src/Provider/Makefile.am
    trunk/Providers/GDAL/Src/Provider/RFP.vcproj
    trunk/Providers/GDAL/Src/UnitTest/UnitTest.vcproj
    trunk/Providers/WMS/configure
    trunk/Providers/WMS/configure.in
    trunk/Providers/WMS/Src/Makefile.am
    trunk/Providers/WMS/Src/Provider/Makefile.am
    trunk/Providers/WMS/Src/Provider/WMSProvider.vcproj
    trunk/Providers/WMS/Src/UnitTest/UnitTest.vcproj
Ticket URL: <http://trac.osgeo.org/fdo/ticket/5#comment:6>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
