[fdo-trac] #28: MySQL: cannot insert into or update foreign schema
class via FDO gateway
trac_fdo at osgeo.org
Mon Mar 5 17:12:29 EST 2007
#28: MySQL: cannot insert into or update foreign schema class via FDO gateway
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: MySQL Provider | Version: 3.2.0
Severity: 2 | Keywords: foreign schema insert
External_id: |
- created a non-FDO datastore with a single table with the following
columns:
id varchar(20) not null.
data varchar(50) null,
geometry geometry,
primary key(id)
- created an FDO datastore and applied a Feature Schema and schema
overrides that
relate a feature class to the above table.
- executed a FdoIInsert command against the feature class. Got the
following
exception:
No column for property 'ClassId'
Ticket URL: <http://trac.osgeo.org/fdo/ticket/28>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
