[fdo-trac] #28: MySQL: cannot insert into or update foreign schema class via FDO gateway
FDO trac_fdo at osgeo.org
Mon Mar 5 17:27:34 EST 2007
 Reporter:  brentrobinson          |         Owner:  brentrobinson
     Type:  defect                 |        Status:  closed
 Priority:  major                  |     Milestone:  3.3.0
Component:  MySQL Provider         |       Version:  3.2.0
 Severity:  2                      |    Resolution:  fixed
 Keywords:  foreign schema insert  |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Modified the FdoIInsert and FdoIUpdate implementations for MySQL Provider
 to ignore system properties that don't have columns. This allows the MySQL
 Provider to handle tables without classid or revisionnumber columns, when
 these tables are accessed via an FDO datastore.
 Revision: 2643
 Author: brentrobinson
 Date: 5:24:22 PM, Monday, March 05, 2007
 Message:
 Ticket #28: Merged Revision 777 from branch 3.2.x: Handle missing system
 properties for externally created tables.
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsInsertCommand.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/28#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
