[fdo-trac] #5: GDAL: Update FDO Thirdparty to latest GDAL Source
trac_fdo at osgeo.org
Wed Mar 7 12:28:01 EST 2007
Reporter: gregboone | Owner: gregboone
Type: enhancement | Status: assigned
Priority: minor | Milestone: 3.3.0
Component: Thirdparty Components | Version: 3.3.0
Severity: 2 | Resolution:
Keywords: GDAL WMS | External_id:
Comment (by gregboone):
I am somewhat concerned about introducing another environment variable
into the build process. Each one adds a little more complexity to the
situation. What if we changed the current build process to key off the
value of FDOGDAL? If it points to /usr/local/fdo-3-3-0 then the build
process will build Thirdparty/GDAL and install in /usr/local/fdo-3-3-0.
Otherwise, the Thirdparty/GDAL will not be built and the FDO providers
will pick-up gdal from the previous installed location such as
/user/local?
[[BR]]
For example...[[BR]]
[[BR]]
'''setenvironment.sh'''[[BR]]
[[BR]]
export FDOGDAL=/usr/local/fdo-3.3.0[[BR]]
[[BR]]
echo ""[[BR]]
echo "NOTE: The setenvironment.sh script sets the installation location
for "[[BR]]
echo "the GDAL SDK files to /usr/local/fdo-3.3.0. If this value remains
unchanged,"[[BR]]
echo "the FDO build process will build the version of GDAL located in
Thirdpaty/gdal"[[BR]]
echo "and will install the resulting files in /usr/local/fdo-3.3.0. The
FDO build"[[BR]]
echo "process will then use that location when building the GDAL
and"[[BR]]
echo "WMS providers. If you wish to build the FDO GDAL or WMS
Providers"[[BR]]
echo "using a previously installed version of GDAL, modify the
setenvironment.sh "[[BR]]
echo "script and set FDOGDAL to point to the existing GDAL
installation."[[BR]]
echo "For example: /user/local (The default GDAL installation
path)."[[BR]]
echo ""[[BR]]
[[BR]]
'''Thirdparty/Thirdparty.sh'''[[BR]]
[[BR]]
## Build Thirdparty_WMS/GDAL[[BR]]
if test "$FDOGDAL" == "/user/local/fdo-3.3.0"; then [[BR]]
pushd . >& /dev/null[[BR]]
cd gdal[[BR]]
echo Building gdal[[BR]]
cd src[[BR]]
chmod a+x ./configure[[BR]]
echo Build GDAL library with the following settings:[[BR]]
echo gif support - internal[[BR]]
echo jpeg support - internal[[BR]]
echo png support - internal[[BR]]
echo tiff support - internal[[BR]]
echo geotiff support - internal[[BR]]
echo libz support - internal[[BR]]
echo python support - no[[BR]]
echo OGR support - no[[BR]]
echo postgreSQL support - no[[BR]]
./configure --with-gif=internal --with-jpeg=internal --with-
png=internal --with-libtiff=internal --with-geotiff=internal --without-ogr
--with-pg=no --with-python=no --with-libz=internal '''--
prefix=/usr/local/fdo-3.3.0'''[[BR]]
make[[BR]]
make install[[BR]]
popd >& /dev/null[[BR]]
else[[BR]]
'''echo "Building Thirdparty/GDAL libraries skipped. FDOGDAL points to
a previously installed version of GDAL at $FDOGDAL"'''[[BR]]
fi[[BR]]
[[BR]]
Ticket URL: <http://trac.osgeo.org/fdo/ticket/5#comment:14>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
