[fdo-trac] #47: More optimized SDF reader handling of string
properties and other performance enhancements
trac_fdo at osgeo.org
Mon Mar 19 14:18:44 EDT 2007
#47: More optimized SDF reader handling of string properties and other
Reporter: badreddinekaroui | Owner: Badreddine Karoui
Type: enhancement | Status: new
Priority: minor | Milestone: 3.3.0
Component: SDF Provider | Version: 3.3.0
Severity: 3 | Keywords:
External_id: |
This enhancement addresses 2 main issues:
1) A regular FDO client would use the class definition to discover and
read the property values of a given class. As a result, after each
ReadNext the properties are accessed in the order they added to the
property definition collection of the class. One of the internal functions
performs a linear search for every property. This change will eliminate
the linear search by keeping a pointer to the last accessed property.
2) The second change implements a more efficient buffer cache for string
properties and minimize memory re-allocation over the lifespan of the
feature reader.
The above 2 changes have a significant performance improvement. For one of
the test SDF files with 2 millions records the time to access all the
records changed from ~140 sec to ~45 sec.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/47>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
