[fdo-trac] #55: ODBC: Native Linux drivers for Oracle, Sybase
    trac_fdo at osgeo.org
    Fri Mar 30 16:24:45 EDT 2007
   Reporter:  gavincramer    |       Owner:  gavincramer
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.3.0
  Component:  ODBC Provider  |     Version:  3.2.0
   Severity:  3              |    Keywords:
External_id:                 |
 ODBC Provider does not work on Linux with the native (vendor-provided)
 drivers for Oracle 10gR2 or Sybase 15.0.  Failures are due to odd
 behaviour or defects in the drivers.  Examples:  Oracle's driver can
 return zero-sized varchar2 columns on some obscure system tables;  Sybase'
 driver advertises support for schemas, but returns none (and the caller
 must know to specify a different "owner" object, "dbo" by default).
 Fixes and workarounds will need to be made to make at least basic
 functionality work with these ODBC drivers.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/55>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
