[fdo-trac] #167: WMS provider should return the default SRS if
supported.
trac_fdo at osgeo.org
Wed Nov 7 13:22:32 EST 2007
#167: WMS provider should return the default SRS if supported.
Reporter: romicadascalescu | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: WMS Provider | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
In some cases WMS provider should return the default SRS (EPSG:4326)if it
is supported.
When capabilities are processed, in case a GeographicBoundingBox is found,
a BoundingBox will be generated and the default SRS will be returned.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/167>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
