[fdo-trac] #171: Fdo Postgis Autogenated identity property is
mandatory
trac_fdo at osgeo.org
Mon Nov 19 11:08:53 EST 2007
#171: Fdo Postgis Autogenated identity property is mandatory
Reporter: bscott | Owner: mloskot
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: PostGIS Provider | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
With FDO it is possible to create a column with Primary = true and
autogenerate = false.
I think the PostGis provider should not do that assumption and let the
user
manage the primary key if the autogenerate flag is set to false.
Actually it is mandatory
there is the piece of code where you can find the limitation:
void SchemaDescription::DescribeSchema(Connection* conn, FdoString*
schemaName)
////////////////// SET AUTO-GENERATED TO SINGLE COLUMN PK OF
INTEGRAL TYPE //////////////////
// TODO: It is possible, that user connects to a datastore that was not
created
// with FDO, using ApplySchema command, so single column PRIMARY KEY
// of integral type, may not have associated sequence named according
scheme:
// <tablename>_<columnname>_seq
// The PostGIS provider uses such scheme to bind a sequence to PK column.
// TODO: In future, it would be a good idea to automatically
// replace PK of integral type with serial data type, in ApplySchema
command.
FdoPtr<FdoDataPropertyDefinitionCollection> propsIdentity;
propsIdentity = featClass->GetIdentityProperties();
if (1 == propsIdentity->GetCount())
FdoPtr<FdoDataPropertyDefinition> propId =
propsIdentity->GetItem(0);
assert(NULL != propId);
if (FdoDataType_Int16 == propId->GetDataType()
|| FdoDataType_Int32 == propId->GetDataType()
|| FdoDataType_Int64 == propId->GetDataType())
propId->SetIsAutoGenerated(true);
Ticket URL: <http://trac.osgeo.org/fdo/ticket/171>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
