[fdo-trac] #177: Support Non-ASCII7 database element names
trac_fdo at osgeo.org
Thu Nov 22 12:52:54 EST 2007
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: closed
Priority: major | Milestone: 3.3.0
Component: GenericRdbms API | Version: 3.3.0
Severity: 2 | Resolution: fixed
Keywords: ASCII7 create table column | External_id:
Changes (by brentrobinson):
* status: new => closed
* resolution: => fixed
Comment:
Revision: 3569
Author: brentrobinson
Date: 12:51:35 PM, Thursday, November 22, 2007
Message:
Ticket#177: Allow GenericRdbms providers to support non-ASCII7 database
element names.
Modified :
/trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsDeleteCommand.cpp
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Mgr.cpp
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Mgr.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err8M_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err8_master.txt
Added :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_err1S_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.txt
Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/DbObject.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp
Modified :
/trunk/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/Index.cpp
Modified :
/trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/PropertyMappingSingle.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaElement.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Column.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Index.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rb/Column.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rb/Table.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialIndex.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/177#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
