[fdo-trac] #182: Expression Function SIGN: Should return INT32
rather than INT16
trac_fdo at osgeo.org
Mon Nov 26 15:50:17 EST 2007
#182: Expression Function SIGN: Should return INT32 rather than INT16
Reporter: thomasknoell | Owner: thomasknoell
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: FDO API | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
The return data type for the expression function SIGN - the function
returns -1, 0 or 1 depending on whether the provided value is less than 0,
0 or greater than 0 - was initialy set to INT16. However, since the SHP
Provider does not support the INT16 data type the function now returns an
INT32. This required a signature change and a change in the section that
returns the result.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/182>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
