[fdo-trac] #188: OGR and PostGIS providers not working under
MapGuide on Ubuntu 7.10
trac_fdo at osgeo.org
Fri Nov 30 17:47:25 EST 2007
#188: OGR and PostGIS providers not working under MapGuide on Ubuntu 7.10
Reporter: jbirch | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: Build System | Version: 3.3.0
Severity: 3 | Resolution:
Keywords: | External_id:
Old description:
> From Jo Cook on the mapguide-users mailing list:
> I have managed to build MGOS2 on Ubuntu 7.04 with help from Jason's great
> instructions on the wiki. However, when I try and make a new data
> connection with either postgis or ogr I get errors.
> In mapguide studio when I try to make a postgis connection I get the
> default feature editor screen and errors in my error log saying
> CLNT_8_UNABLE_TO_LOAD_LIBRARY.
> When I make an ogr connection I get the proper editor (with data source
> and readonly connection options) but I get a connection failed error when
> I try and test the connection. The error log says
> CLNT_4_PROVIDERNOTREGISTERED.
> I have tested my connection string with ogrinfo and it works, and I have
> checked that both providers are in my providers.xml file.
> I have also tested both connection strings with testconnection in the web
> tier test suite and both give me the CLNT_4_PROVIDERNOTREGISTERED error.
> Has anyone successfully managed to use either of these connectors with
> Ubuntu, and how do I begin debugging the problem?
> Many thanks
> Jo
New description:
great instructions on the wiki. However, when I try and make a new
data connection with either postgis or ogr I get errors.
the default feature editor screen and errors in my error log
saying CLNT_8_UNABLE_TO_LOAD_LIBRARY.
source and readonly connection options) but I get a connection
failed error when I try and test the connection. The error log
says CLNT_4_PROVIDERNOTREGISTERED.
and I have checked that both providers are in my providers.xml
file.
the web tier test suite and both give me the
with Ubuntu, and how do I begin debugging the problem?
Ticket URL: <http://trac.osgeo.org/fdo/ticket/188#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
