[fdo-trac] #128: PATCH: OGR Provider, slight speedup and override of projections
FDO trac_fdo at osgeo.org
Wed Oct 3 10:05:58 EDT 2007
#128: PATCH: OGR Provider,slight speedup and override of projections
   Reporter:  traianstanev  |       Owner:  traianstanev
       Type:  enhancement   |      Status:  new
   Priority:  minor         |   Milestone:  3.3.0
  Component:  OGR Provider  |     Version:  3.2.0
   Severity:  3             |    Keywords:
External_id:                |
 This ticket reflects a patch submission by Kenneth. Here is his summary:
 The attached file contains an improvement to the OGR Provider.
 The patch will avoid checking intersection in cases where the query type
 is a EnvelopIntersect.
 The current intersection check was added to ensure that the AJAX Viewers
 select and tooltip operations works.
 However, this check slows down the renderer because it performs an actual
 intersection test, which is not required for rendering.
 Aditionally I have removed all "printf" commands from a non-debug build.
 Lastly, I have added an option to supply coordinate system overrides on
 the provider.
 This is necessary for certain MI_TAB files, which use non standard WKT
 projections.
 It will read in a file named "projections.txt" from the server folder.
 The "projections.txt" file should be constructed like this (wkt is
 supposed to be full):
 #System 34 S
 PROJCS["unnamed" ....... 1.0]]
 PROJCS["DenmarkS34-S" ....... 1.0 ]]
 Any blank line or line starting with # is ignored.
 Every two accepted lines are treated as a pair, where the first line is
 the WKT translated from, and the second line is the WKT translated to.
 It uses a std::map which will run in O(1) to find the projections.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/128>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
