[fdo-trac] #138: SDF and SHP: Fix the scrollable reader handling of computed identifiers with NULL and String values
FDO trac_fdo at osgeo.org
Fri Oct 19 15:03:17 EDT 2007
   Reporter:  badreddinekaroui  |       Owner:  gregboone
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.3.0
  Component:  FDO API           |     Version:  3.3.0
   Severity:  3                 |    Keywords:
External_id:                    |
 The SDF provider is not handling computed identifier with null values
 properly.
 And the SHP is not flushing the string buffer it uses for the computed
 identifier values. This is only true when teh scrollable reader is used.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/138>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
