[fdo-trac] #118: PostGIS provider appears to be double-quoting
geometry columns
trac_fdo at osgeo.org
Tue Sep 11 03:41:20 EDT 2007
#118: PostGIS provider appears to be double-quoting geometry columns
Reporter: jbirch | Owner: mloskot
Type: defect | Status: new
Priority: critical | Milestone: 3.3.0
Component: PostGIS Provider | Version: 3.2.2
Severity: 3 | Keywords:
External_id: |
This appears to be a problem in the filter application, and is quite
noticible with MapGuide. MapGuide attempts a three-phase query, the last
of which is an unfiltered selection. When querying PostGIS, the first two
queries fail with a warning like this:
DECLARE crsselcmd_118158d9f60b36a01e666071e02bf774 CURSOR FOR SELECT
"public"."county_bnd".geom FROM "public"."county_bnd" WHERE ( geom &&
GeomFromWKB(decode(''01030000000100000005000000A8101DFEC4070041FDFFFF7F519C3641D6BB780834242641FDFFFF7F519C3641D6BB78083424264103000020B75F3D41A8101DFEC407004103000020B75F3D41A8101DFEC4070041FDFFFF7F519C3641'',
'hex'),26767) AND
Intersects(geom,GeomFromWKB(decode(''01030000000100000005000000A8101DFEC4070041FDFFFF7F519C3641D6BB780834242641FDFFFF7F519C3641D6BB78083424264103000020B75F3D41A8101DFEC407004103000020B75F3D41A8101DFEC4070041FDFFFF7F519C3641'',
'hex'),26767)) )
Number of parameters: 0
23:57:14:946 (0x00000210) : ERROR: SQL command failed:
[PGRES_FATAL_ERROR] ERROR: syntax error at or near
"01030000000100000005000000"
LINE 1: ...county_bnd" WHERE ( geom && GeomFromWKB(decode(''0103000000...
This appears to be a problem that was introduced with the new automatic
quoting of the geometry hex value. It appears that there may be extra
quotes added on the following lines:
http://trac.osgeo.org/fdo/browser/trunk/Providers/PostGIS/Src/Provider/FilterProcessor.cpp#L311
http://trac.osgeo.org/fdo/browser/trunk/Providers/PostGIS/Src/Provider/FilterProcessor.cpp#L435
I suppose it is possible there are more?
Ticket URL: <http://trac.osgeo.org/fdo/ticket/118>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
