[fdo-trac] #367: Eliminate nested filter SQL statements if nesting is not required
FDO trac_fdo at osgeo.org
Wed Aug 6 16:29:29 EDT 2008
 Reporter:  thomasknoell      |         Owner:  thomasknoell
     Type:  defect            |        Status:  closed
 Priority:  major             |     Milestone:
Component:  GenericRdbms API  |       Version:  3.2.0
 Severity:  3                 |    Resolution:  fixed
 Keywords:                    |   External_id:
Changes (by thomasknoell):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 The issue has been fixed. The following files were added or modified:
 Adding: Providers\GenericRdbms\Src\UnitTest\Common\FdoFilterTest.cpp
 Adding: Providers\GenericRdbms\Src\UnitTest\Common\FdoFilterTest.h
 Adding: Providers\GenericRdbms\Src\UnitTest\MySql\MySqlFdoFilterTest.cpp
 Adding: Providers\GenericRdbms\Src\UnitTest\MySql\MySqlFdoFilterTest.h
 Adding:
 Providers\GenericRdbms\Src\UnitTest\SQLServerSpatial\SqlServerFdoFilterTest.cpp
 Adding:
 Providers\GenericRdbms\Src\UnitTest\SQLServerSpatial\SqlServerFdoFilterTest.h
 Modified: Providers\ArcSDE\Src\Provider\ArcSDEFilterToSql.cpp
 Modified: Providers\ArcSDE\Src\Provider\ArcSDEFilterToSql.h
 Modified: Providers\ArcSDE\Src\Provider\ArcSDEUtils.cpp
 Providers\GenericRdbms\Src\Fdo\Filter\FdoRdbmsFilterProcessor.cpp
 Modified: Providers\GenericRdbms\Src\Fdo\Filter\FdoRdbmsFilterProcessor.h
 Modified: Providers\GenericRdbms\Src\UnitTest\Common\Makefile.am
 Modified: Providers\GenericRdbms\Src\UnitTest\MySql\Makefile.am
 Modified: Providers\GenericRdbms\Src\UnitTest\UnitTestMySql.vcproj
 Providers\GenericRdbms\Src\UnitTest\UnitTestSQLServerSpatial.vcproj
 Providers\GenericRdbms\Src\ODBC\Fdo\FdoRdbmsOdbcFilterProcessor.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/367#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
