[fdo-trac] #371: Sql Server 2008: Filter test references an
incorrect header file
trac_fdo at osgeo.org
Fri Aug 8 09:43:07 EDT 2008
#371: Sql Server 2008: Filter test references an incorrect header file
Reporter: thomasknoell | Owner: thomasknoell
Type: defect | Status: new
Priority: major | Milestone:
Component: FDO API | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
The filter test added to the SQL Server 2008 unit test suites references
an incorrect header file. This ticket is to replace it with the correct
one.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/371>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
